Common gotchas with Verge3D
Huge shadow maps
Swapping object on click
Inconsistent colors when using Alpha Hashed (Coverage) transparency
There is a known issue when dealing with alpha hashed transparency. When rendering, the browser mixes-in the background color taken from the <canvas> element even if the scene background is explicitly set to be non-transparent. Use the following puzzle to make alpha hashed transparency work properly:
