Common gotchas with Verge3D
Revision as of 07:19, 14 October 2025 by Alexander (talk | contribs)
Huge shadow maps
Swapping object on click
The exec script puzzle won't work for custom CSS code, since CSS is not a scripting language. Basically, the following puzzle will fail with syntax error:
Instead you should create a new <style> element and insert you custom CSS as its "textContent" property:
