verge3d-blender-4.9.2.exe /S
python3 setupAddon.py
python3 install.py
Verge3D for 3ds Max:
Verge3D for Maya:
Internet resources used
In order to use Verge3D efficiently, you might need to provide internet access to the following web resources (directly or via VPN):
| Host | Port | Notes |
| cdn.soft8soft.com | 443 | Verge3D Asset Store, Verge3D Network CDN |
See Also
