Common gotchas with Verge3D
Revision as of 12:28, 23 June 2022 by Alexander (talk | contribs)
Huge shadow maps
Swapping object on click
There will be one of the two consequences of it.
  1. Case 1 (bad). You won't be able to load your scene, since your app expects the compressed asset (e.g my_awesome_app.gltf.xz) which is unavailable.
  1. Case 2 (even worse). You have file called my_awesome_app.gltf.xz in your app which you exported using
