Common gotchas with Verge3D
Revision as of 12:05, 11 September 2025 by Alexander (talk | contribs)
Huge shadow maps
Swapping object on click
Alternatively, you could swap your objects with just one "when clicked" puzzle:
Forgetting to disable offline mode or refresh cache
Once you activate Offline Mode in App Manager settings, persistent app cache will be created and populated on the first launch.
This cache will be reused for all subsequent launches, making it impossible to reflect any modifications made to the app. You can either press Refresh Cache any time you make changes or, which is better, keep offline mode disabled during the app development.
