Jump to navigationJump to searchThis page provides tips for setting up Verge3D in large-scale production environments, such as animation studios and educational institutions.
verge3d-blender-4.9.2.exe /S
Using Linux version on Windows/macOS
The Verge3D's .xz distribution is intended to be installed on Linux/ChromeOS. Still, you can unpack it and use on macOS / Windows as well! Just follow the Linux guidelines from the User Manual:
See Also
