Common gotchas with Verge3D
Huge shadow maps
Swapping object on click
Situation #1 (bad). You won't be able to load your scene, since your app expects the compressed asset (e.g my_awesome_app.gltf.xz) which is unavailable. As a result the app preloader will freeze forever.
Situation #2 (even worse). You have file called my_awesome_app.gltf.xz in your app which you exported earlier. As a result it is now out of sync with the uncompressed version (my_awesome_app.gltf), and so with your source scene (.blend/.max/.mb). You will have hard time trying to figure out why Verge3D rendering no longer reflects the changes you make in your scene.
