Common gotchas with Verge3D
Huge shadow maps
Swapping object on click
There will be one of the two consequences of it.
  1. Case (bad). You won't be able to load your scene, since your app expects the compressed asset (e.g my_awesome_app.gltf.xz) which is unavailable.
  2. Case (even worse). You have file called my_awesome_app.gltf.xz in your app which you exported using
