verge3d-blender-4.9.2.exe /S
Using Linux version on Windows/macOS
The Verge3D's .xz distribution is intended to be installed on Linux/ChromeOS. Still, you can unpack it and use on macOS / Windows as well! To setup the exporter plugins for Blender and Maya, follow the Linux guidelines from the User Manual:
Verge3D for 3ds Max is available for Windows only, hence no .xz build (fixable by using Verge3D Ultimate).
See Also
