Coordinate Systems
Verge3D
Blender
3ds Max
On the other hand, Maya, most game engines, graphics APIs, and of course Verge3D use another approach: your screen is a plain with X/Y coordinates while Z is the scene depth.
Maya
Coordinate System Conventions
| Bullet/Ammo.js | Y-up | right-handed | |
| Houdini | Y-up | right-handed | |
| Maya | Y-up | right-handed | configurable to Z-up right-handed |
| OpenGL/WebGL/glTF | Y-up | right-handed | |
