Coordinate Systems
Verge3D
In Verge3D we use right-handed coordinate system with Y axis pointing in the up direction.
Blender
3ds Max
Autodesk 3ds Max uses right-handed coordinate system with Z axis pointing in the up direction. This convention is similar to Blender.
Maya
By default, Autodesk Maya uses right-handed coordinate system with Y axis pointing in the up direction. This convention is similar to Verge3D.
Coordinate System Conventions
| Bullet/Ammo.js | Y-up | right-handed | |
| Houdini | Y-up | right-handed | |
| Maya | Y-up | right-handed | configurable to Z-up right-handed |
| OpenGL/WebGL/glTF | Y-up | right-handed | |
| Verge3D | Y-up | right-handed |
