How to debug Puzzles
Revision as of 12:56, 23 March 2026 by Alexander (talk | contribs)
This short but very important how-to explains how to find and fix bugs in your Puzzles scenarios.
If you execute Puzzles incorrectly, e.g. by passing invalid inputs, they will fail to work and print the explanation in the browser console. To open it just press F12 and switch to the Console tab (works in most cases, if not, refer to the instructions).
Check out the following example that explain the idea. Consider you need to replace texture on some of your models with the replace texture puzzle, but nothing happens once you execute this puzzle.
Use print to console puzzle
Let's explain it with the following example. Consider you need to calculate a position with some function ("calc object position") and then place some object to this position with the set transform puzzle. Once you've done with your scenario, you see that the object is not placed correctly. What should you do first? Yes, you should open the browser console!
Here we go:
Once you've done with bug fixing, don't forget to remove the "print to console" puzzle(s) to prevent cluttering of the browser console.
Summary
  1. open (F12) the browser console and look for errors. Not helpful? Go to step 2.
