How to debug Puzzles
Yep, you've specified invalid path to the texture! Fix the path and reload the app to see that the issue has gone.
Use print to console puzzle
Let's explain it with the following example. Consider you need to calculate a position with some function ("calc object position") and then place some object to this position with the set transform puzzle. Once you've done with calculations, you see the object is not placed correctly. You already know that you should open the browser console first. Opening it you don't see any errors!
This means you should insert the "print to console" to your scenario but where? At the first glance you should place it just before the actual object positioning takes place.
Here we see the position returned by the "calc object position". In our case it has zero values for all 3 coordinates (XYZ). Now it's time to review the "calc object position" and check for possible errors happening in that function. If necessary insert as many "print to console" puzzle as necessary to find the cause of the issue.
Once you've done with fixing the bug, remove "print to console" puzzle to prevent cluttering of the browser console.
Summary
- open the browser console and look for errors
- insert print to console and carefully read its output
