Installing Maya on Linux
Revision as of 17:29, 12 February 2026 by Alexander (talk | contribs) (Additional Maya components (informative section))
Maya 2024 on Fedora 39
Install dependencies:
sudo dnf install libnsl
sudo dnf install libpng15
sudo dnf install libGLU
sudo dnf install mesa-libGLw
sudo dnf install libxcrypt-compat
Run with:
maya --single-process
Maya 2023 on Ubuntu
See here.
Maya on ArchLinux
See AUR package here.
StartupWMClass=maya.bin
See the installed package contents here:
This is the main desktop licensing service (Autodesk Desktop Licensing Service). It manages named-user licensing (the modern subscription model), checks out licenses from Autodesk servers, validates your subscription, and enables the software to run. Installed with 2020+ products and runs as a background service.
/opt/Autodesk/AdskLicensing/
/opt/Autodesk/Adlm/FLEXnet/
/opt/Autodesk/Adlm/
AdODIS (Autodesk On-Demand Installation Services)
Autodesk modern installer backend. Handles downloading components on-demand, silent/unattended installations, updates to installation-related services, repairs, and clean removals.
/usr/local/Autodesk/AdODIS
AdskCER (Autodesk Customer Error Reporting)
Autodesk crash reporting tool.
