Installing Maya on Linux
If you need Maya to work seamlessly on Linux, you should use the distro recommended by Autodesk (e.g RHEL/Rocky). However, it's possible to install Maya on other distros by applying various hacks which we discuss here.
Maya 2025-2027
These versions have many issues when installed on unsupported distros: errors during installation, failed licensing verification, a black screen in Viewport 2.0, etc. The only viable option for installing Maya 2025–2027 on Linux is to use Red Hat/Rocky 9 (exactly this version; Red Hat/Rocky 10 will not work).
Maya 2024 on Fedora 39
Install dependencies:
Run with:
maya --single-process
Maya 2023 on Ubuntu
See here.
Maya on ArchLinux
See AUR package here.
StartupWMClass=maya.bin
This handles user authentication and single sign-on (SSO).
See the installed package contents here:
It checks out licenses from Autodesk servers, validates your subscription, and enables the software to run.
/opt/Autodesk/AdskLicensing/
This is the client-side part of FlexNet (formerly FLEXlm) licensing technology. It communicates with license servers for network/multi-user licenses.
/opt/Autodesk/Adlm/FLEXnet/
/opt/Autodesk/Adlm/
AdODIS (Autodesk On-Demand Installation Services)
Autodesk modern installer backend. Handles downloading components on-demand, silent/unattended installations, updates to installation-related services, repairs, and clean removals.
/usr/local/Autodesk/AdODIS
AdskCER (Autodesk Customer Error Reporting)
Autodesk crash reporting tool.
