Installing Maya on Linux
Maya 2024 on Fedora 39
Install dependencies:
Run with:
maya --single-process
Maya 2023 on Ubuntu
See here.
== Maya on ArchLinux
See AUR package here.
StartupWMClass=maya.bin
