Coordinate Systems
Verge3D
So, it does not matter which Verge3D flavor you use: for Blender, 3ds Max, or Maya. In all these cases the internal coordinate system would be the same - Y-up.
Blender
X (Blender) →  X (Verge3D)
Y (Blender) → -Z (Verge3D)
Z (Blender) →  Y (Verge3D)
3ds Max
Maya
Coordinate System Conventions
3ds Max Z-up right-handed
Blender Z-up right-handed
Cinema4D Y-up left-handed
DirectX Y-up left-handed
Unity Y-up left-handed
Verge3D Y-up right-handed
WebGPU Y-up left-handed
