Verge3D 4.0 migration guide
Short Memo
- Install Verge3D 4.0.
 - Re-save Puzzles.
Major Changes
Removal of deprecated puzzles
Directory Split
 - Application files.
 - Configuration files.
Puzzles Library
App Manager Templates
Puzzles Plugins
- Blender 2.80-2.82
 - 3ds Max 2019
 - Maya 2018
Removed deprecated Puzzles-based AO
