Verge3D 4.0 migration guide
Revision as of 12:32, 3 June 2022 by Alexander (talk | contribs)
Short Memo
  1. Install Verge3D 4.0.
  5. Re-save Puzzles.
Major Changes
Removal of deprecated puzzles
Directory Split
  2. Application files.
  3. Configuration files.
Puzzles Library
App Manager Templates
Puzzles Plugins
Dropped support for older versions of modelling suites
In Verge3D 4.0, the following versions of the modelling suites no longer supported:
  • Blender 2.80-2.82
  • 3ds Max 2019
  • Maya 2018
