Verge3D 4.0 migration guide
Short Memo
  1. Install Verge3D 4.0.
  5. Re-save Puzzles.
Major Changes
Removal of deprecated puzzles
Deprecated puzzles are now removed and replaced by dummy blocks. Please update your Puzzles scripts before migrating to Verge3D 4.0.
Directory Split
  2. Application files.
  3. Configuration files.
Puzzles Library
App Manager Templates
Puzzles Plugins
