Verge3D 4.0 migration guide
Short Memo
  1. Install Verge3D 4.0.
  2. Launch App Manager. When it asks to specify a new application directory, leave default or choose existing (e.g verge3d_blender/applications).
  3. Update your apps in App Manager using build-in updater.
  4. Reexport your Blender/3ds Max/Maya assets.
  5. Resave Puzzles.
Major Changes
Directory Split
  2. Application files.
  3. Configuration files.
Now we store them separately:
  1. Verge3D software files now installed in the separate read-only directory (e.g Program Files on Windows).
  2. Application files now stored in the explicitly selected directory (e.g Documents\verge3d_apps).
  3. Configuration files go to system-specific place (e.g AppData\Roaming\Soft8Soft\Verge3D for Blender).
  4. Temporary directory go to system-specific place (e.g AppData\Local\Temp) and automatically cleared up on exit.
Puzzles Library
So you should copy the file called my_library.xml from e.g verge3d_blender/puzzles of your old Verge3D 3.X installation to your applications folder.
App Manager Templates
Puzzles Plugins
