Common gotchas with Verge3D
This page includes common gotchas you might experience when creating 3D web content. These issues might cause problems with rendering or performance (or both).
Enabling HDR Rendering when it's not required
Huge shadow maps
Setting shadow size to high value basically kills performance on most devices:
Try to minimize these as much as possible!
