Coordinate Systems
Revision as of 14:01, 9 September 2021 by Alexander (talk | contribs) (add screenshots)
Verge3D
In Verge3D we use right-handed coordinate system with Y axis pointing in the up direction.
Blender
3ds Max
Autodesk 3ds Max uses right-handed coordinate system with Z axis pointing in the up direction. This convention is similar to Blender.
Maya
By default, Autodesk Maya uses right-handed coordinate system with Y axis pointing in the up direction. This convention is similar to Verge3D.
Coordinate System Conventions
3ds Max Z-up right-handed
Blender Z-up right-handed
Cinema4D Y-up left-handed
DirectX Y-up left-handed
Houdini Y-up right-handed
Unity Y-up left-handed
Verge3D Y-up right-handed
