How to debug Puzzles
This short but very important how-to explains how to find and fix bugs in your Puzzles scenarios.
If you execute Puzzles incorrectly, e.g. by passing invalid inputs, they will fail to work and print the explanation in the browser console. To open it just press F12 and switch to the Console tab (works in most cases, if not, refer to the instructions).
Check out the following example that explain the idea. Consider you need to replace texture on some of your models with the replace texture puzzle, but nothing happens once you execute this puzzle.
Use print to console puzzle
Your scenario behaves odd, but there is no errors in the browser console? Just insert the print to console puzzle in the right places and pass meaningful data to this puzzle as input.
What places? What data?
Let's explain it with the following example. Consider you need to calculate a position with some function ("calc object position") and then place some object to this position with the set transform puzzle. Once you've done with your scenario, you see that the object is not placed correctly. What should you do first? Yes, you should open the browser console!
Here we go:
Printing to console is considered the most straightforward and efficient method of debugging. It's also very helpful to understand what your script is actually doing. Again, don't hesitate to add as many "print to console" as possible. Print everything! Variables, function return values, values returned by the "get..." puzzles. Even plain "Here am I" string might be of some value.
Summary
- open (F12) the browser console and look for errors. Not helpful? Go to step 2.
- insert print to console in the right place/places and carefully read their output
