How to debug Puzzles
This short but important how-to explains how to find and fix bugs in your Puzzles scenarios.
If you execute Puzzles incorrectly, e.g. by passing invalid inputs, they will fail to work and print the explanation in the browser console (see here for instructions to open it).
Use print to console puzzle
Here we go:
Once you've done with bug fixing, always remove the "print to console" puzzle(s) to prevent cluttering of the browser console.
Summary
- open the browser console and look for errors
- insert print to console in the right place/places and carefully read their output
