How to debug Puzzles
Use print to console puzzle
Here we go:
Once you've done with bug fixing, always remove the "print to console" puzzle(s) to prevent cluttering of the browser console.
Summary
- open the browser console and look for errors
- insert print to console in the right place/places and carefully read their output
