How to debug Puzzles
Revision as of 15:56, 21 March 2026 by Alexander (talk | contribs)
Use print to console puzzle
Let's explain it with the following example. Consider you need to calculate a position with some function ("calc object position") and then place some object to this position with the set transform puzzle. Once you've done with your scenario, you see that the object is not placed correctly. What should you do first? Yep, open the browser console! Unfortunately there are no issues there:
This means you should switch to plan B and insert the "print to console" puzzle to your scenario. But where? At the first glance you should place it just before the actual object positioning takes place. Here we go:
Summary
  1. open the browser console and look for any errors
