Verge3D 4.0 migration guide
Revision as of 07:33, 21 March 2026 by Alexander (talk | contribs)
Short Memo
  1. Install Verge3D 4.0.
  5. Re-save Puzzles.
Major Changes
Removal of deprecated puzzles
Directory Split
  2. Application files.
  3. Configuration files.
Puzzles Library
App Manager Templates
Puzzles Plugins
  • Blender 2.80-2.82
  • 3ds Max 2019
  • Maya 2018
Removed deprecated Puzzles-based AO
Changed Verge3D Network file hierarchy
    <head>
    </head>
https://cdn.soft8soft.com/AROAJSY2GOEHMOFUVPIOE:xxxxxxxxxx/applications/my_awesome_app/index.html
to:
https://cdn.soft8soft.com/AROAJSY2GOEHMOFUVPIOE:xxxxxxxxxx/my_awesome_app/index.html
