Creating installers for Verge3D plugins
Revision as of 07:57, 18 July 2025 by Alexander (talk | contribs)
By using NSIS (Nullsoft Scriptable Install System) you can wrap your plugins to user-friendly installers. Contrary to manual ZIP distribution, installers search for Verge3D distros and automatically copy plugin files to the required plugin folders. Also, installers display licensing info, help URLs, and create necessary scripts to uninstall your products.
Unicode true
SetCompress off
SetCompressor /SOLID lzma
!include "MUI2.nsh"
RequestExecutionLevel highest
!include LogicLib.nsh
# interface Settings
!define MUI_ABORTWARNING
# pages
!insertmacro MUI_PAGE_WELCOME
!insertmacro MUI_PAGE_FINISH
Section
    SectionIn RO
    SetOutPath "$INSTDIR"
    File LICENSE.txt
    ClearErrors
    ${IfNot} ${Errors}
    ${EndIf}
    ClearErrors
    ${IfNot} ${Errors}
    ${EndIf}
    ClearErrors
    ${IfNot} ${Errors}
    ${EndIf}
    ClearErrors
    ${IfNot} ${Errors}
    ${EndIf}
SectionEnd
Section "Uninstall"
    ClearErrors
    ${IfNot} ${Errors}
    ${EndIf}
    ClearErrors
    ${IfNot} ${Errors}
    ${EndIf}
    ClearErrors
    ${IfNot} ${Errors}
    ${EndIf}
    ClearErrors
    ${IfNot} ${Errors}
    ${EndIf}
    Delete "$INSTDIR\*.*"
    RMDir "$INSTDIR"
SectionEnd
