Verge3D 4.0 migration guide
Short Memo
  1. Install Verge3D 4.0.
  5. Re-save Puzzles.
Major Changes
Removal of deprecated puzzles
Directory Split
  2. Application files.
  3. Configuration files.
Puzzles Library
App Manager Templates
Puzzles Plugins
  • Blender 2.80-2.82
  • 3ds Max 2019
  • Maya 2018
Removed deprecated Puzzles-based AO
Changed Verge3D Network file hierarchy
In order to migrate to new URLs without braking the older links, you might use the following trick.
  1. Go to the Verge3D user directory, and create a folder named "applications".
  1. Create a subfolder inside the applications folder called "MyAwesomeApp".
  1. Put a file named "index.html" to that subfolder (if you developed app in the iframe) or "my_awesome_app.html" (if you developed a stand-alone app) with the following contents:
<head>
</head>
  1. Launch the App Manager, and upload the "applications" app to Verge3D Network .
