Coordinate Systems
Verge3D
Blender
3ds Max
Now it's time for history lesson. Both Blender and 3ds Max use coordinate system which were common in early 90's. This convention is typical in architecture - you start modelling from the floor plan which uses X/Y coordinates and then extrude upwards (or downwards). On the other hand, Maya, most game engines, graphics APIs, and of course Verge3D use different approach. The screen becomes a 2D plain which uses X/Y coordinates to position flat images, while Z coordinate adds depth to the scene. That's why the buffer that stores pixel depth is called Z-buffer and the issue with limited depth precision is called Z-fighting.
Maya
Coordinate System Conventions
| Bullet/Ammo.js | Y-up | right-handed | |
| Houdini | Y-up | right-handed | |
| Maya | Y-up | right-handed | configurable to Z-up right-handed |
| OpenGL/WebGL/glTF | Y-up | right-handed | |
