Coordinate Systems
Revision as of 16:14, 9 September 2021 by Alexander (talk | contribs) (3ds Max)
Verge3D
Blender
X (Blender) ->  X (Verge3D)
Y (Blender) -> -Z (Verge3D)
Z (Blender) ->  Y (Verge3D)
3ds Max
On the other hand, Maya, most game engines, graphics APIs, and of course Verge3D use another approach: your screen is a plain with X/Y coordinates while Z is the scene depth.
Maya
Coordinate System Conventions
3ds Max Z-up right-handed
Blender Z-up right-handed
Cinema4D Y-up left-handed
DirectX Y-up left-handed
Houdini Y-up right-handed
Unity Y-up left-handed
Verge3D Y-up right-handed
