How to debug Puzzles
Use print to console puzzle
What places? What data?
Here we go:
Printing to console is considered the most straightforward and efficient method of debugging. It's also very helpful for understanding what your script is actually doing. Again, don't hesitate to add as many "print to console" as possible. Print everything! Variables, function return values, values returned by the "get..." puzzles. Even plain "Here am I" string might be of some value.
Summary
- open (F12) the browser console and look for errors. Not helpful? Go to step 2.
- insert print to console in the right place/places and carefully read their output
