How to debug Puzzles
Revision as of 16:03, 21 March 2026 by Alexander (talk | contribs)
Use print to console puzzle
Here we go:
Once you've done with bug fixing, always remove the "print to console" puzzle(s) to prevent cluttering of the browser console.
Summary
  1. open the browser console and look for errors
