How to debug Puzzles
Revision as of 16:00, 21 March 2026 by Alexander (talk | contribs) (Summary)
Use print to console puzzle
This means you should switch to plan B and insert the "print to console" puzzle into your scenario. But where? At the first glance you should place it just before the actual object positioning takes place.
Here we go:
Summary
  1. open the browser console and look for errors
