Coordinate Systems
Revision as of 07:30, 21 March 2026 by Alexander (talk | contribs)
In this article you will find info on coordinate systems used in different flavors of Verge3D as well as 3D modeling software.
Verge3D
Blender
X (Blender) →  X (Verge3D)
Y (Blender) → -Z (Verge3D)
Z (Blender) →  Y (Verge3D)
3ds Max
Maya
Coordinate System Conventions
3ds Max Z-up right-handed
Blender Z-up right-handed
Cinema4D Y-up left-handed
DirectX Y-up left-handed
Rhino 3D Z-up right-handed
Unity Y-up left-handed
Verge3D Y-up right-handed
WebGPU Y-up left-handed
