Installing Maya on Linux
Maya 2024 on Fedora 39
Install dependencies:
sudo dnf install libnsl
sudo dnf install libpng15
sudo dnf install libGLU
sudo dnf install mesa-libGLw
sudo dnf install libxcrypt-compat
Run with:
maya --single-process
Maya 2023 on Ubuntu
See here.
Maya on ArchLinux
See AUR package here.
StartupWMClass=maya.bin
This is the main desktop licensing service (Autodesk Desktop Licensing Service). It manages named-user licensing (the modern subscription model), checks out licenses from Autodesk servers, validates your subscription, and enables the software to run. Installed with 2020+ products and runs as a background service.
