Installing Maya on Linux
Revision as of 16:03, 12 February 2026 by Alexander (talk | contribs)
Maya 2024 on Fedora 39
Install dependencies:
sudo dnf install libnsl
sudo dnf install libpng15
sudo dnf install libGLU
sudo dnf install mesa-libGLw
sudo dnf install libxcrypt-compat
Run with:
maya --single-process
Maya 2023 on Ubuntu
See here.
== Maya on ArchLinux
See AUR package here.
StartupWMClass=maya.bin
