Installing Maya on Linux
Revision as of 17:59, 2 May 2025 by Alexander (talk | contribs) (Maya 2022 on Ubuntu)
Maya 2024 on Fedora 39
Install dependencies:
sudo dnf install libnsl
sudo dnf install libpng15
sudo dnf install libGLU
sudo dnf install mesa-libGLw
sudo dnf install libxcrypt-compat
Run with:
maya --single-process
Maya 2023 on Ubuntu
See here.
StartupWMClass=maya.bin
