Библиотека материалов Verge3D для Maya Промышленная
9.900
Обширный пакет промышленных материалов для Autodesk Maya. Содержит 79 шейдеров, включая металлы, краски, пластик, резину и стекло.
Артикул: V3D-MYMM Категория: Метка:
Эта библиотека содержит готовые материалы, подходящие для визуализации элементов техники. Библиотека совместима с системой референсов Maya, что позволяет назначать материалы посредством выбора из меню.
Кликните на иконку, чтобы посмотреть как выглядит соответствующий материал:
Металлы
Aluminium material exported from Maya to WebGLBrass material exported from Maya to WebGLBronze material exported from Maya to WebGLBrushed aluminium material exported from Maya to WebGLBrushed brass material exported from Maya to WebGLBrushed nickel material exported from Maya to WebGLBrushed steel material exported from Maya to WebGLBrushed titanium material exported from Maya to WebGLCast iron material exported from Maya to WebGLChrome material exported from Maya to WebGLCircular polished aluminum material exported from Maya to WebGLCircular polished steel material exported from Maya to WebGLCopper material exported from Maya to WebGLFishskin polished aluminum material exported from Maya to WebGLFishskin polished steel material exported from Maya to WebGLGalvanized steel material exported from Maya to WebGLHammered aluminum material exported from Maya to WebGLHammered brass material exported from Maya to WebGLHammered copper material exported from Maya to WebGLNickel material exported from Maya to WebGLScratched aluminum material exported from Maya to WebGLScratched brass material exported from Maya to WebGLScratched bronze material exported from Maya to WebGLScratched copper material exported from Maya to WebGLScratched nickel material exported from Maya to WebGLScratched steel material exported from Maya to WebGLScratched titanium material exported from Maya to WebGLScratched tungsten material exported from Maya to WebGLSteel material exported from Maya to WebGLTitanium material exported from Maya to WebGLTungsten material exported from Maya to WebGL
Лакокрасочные покрытия
Fine oil paint material exported from Maya to WebGLMetal enamel material exported from Maya to WebGLShagreen paint material exported from Maya to WebGL
Пластмассы
ABS (acrylonitrile butadiene styrene) plastic material exported from Maya to WebGLBarkbeetle ABS (acrylonitrile butadiene styrene) plastic material exported from Maya to WebGLGraphite filled nylon material exported from Maya to WebGLLeather ABS (acrylonitrile butadiene styrene) plastic material exported from Maya to WebGLNylon material exported from Maya to WebGLPeel ABS (acrylonitrile butadiene styrene) plastic material exported from Maya to WebGLPolypropylene fiber material exported from Maya to WebGLPOM (polyoxymethylene) plastic material exported from Maya to WebGLRough ABS (acrylonitrile butadiene styrene) plastic material exported from Maya to WebGL
Резины
Polyurethane material exported from Maya to WebGLRubber material exported from Maya to WebGLSilicone material exported from Maya to WebGL
Листовые металлы
Capsule hole aluminum grids material exported from Maya to WebGLDuet sheet aluminum material exported from Maya to WebGLDuet sheet steel material exported from Maya to WebGLLentil sheet aluminum material exported from Maya to WebGLLentil sheet steel material exported from Maya to WebGLQuintet sheet aluminum material exported from Maya to WebGLQuintet sheet steel material exported from Maya to WebGLRhombus sheet aluminum material exported from Maya to WebGLRhombus sheet steel material exported from Maya to WebGLRound hole aluminum grid material exported from Maya to WebGLSteel diamond net material exported from Maya to WebGLSteel square wire material exported from Maya to WebGLSteel wire fence material exported from Maya to WebGL
Листовые пластики
Carbon material exported from Maya to WebGLFiberglass material exported from Maya to WebGLHex hole ABS grid material exported from Maya to WebGLPolypropylene fiber material exported from Maya to WebGLRectangle hole ABS (acrylonitrile butadiene styrene) grid material exported from Maya to WebGLRound hole ABS (acrylonitrile butadiene styrene) grid material exported from Maya to WebGLTextolite material exported from Maya to WebGL
Стёкла
Crust solid glass material exported from Maya to WebGLPyramid solid glass material exported from Maya to WebGLRhombus solid glass material exported from Maya to WebGLRibbed solid glass material exported from Maya to WebGLSolid glass material exported from Maya to WebGL
3Д-печать
WebGL preview of printing filament ABS material exported from 3ds Max to glTF/GLB WebGL preview of printing filament Nylon material exported from 3ds Max to glTF/GLBWebGL preview of printing filament Nylon GF material exported from 3ds Max to glTF/GLB WebGL preview of printing filament PETG material exported from 3ds Max to glTF/GLB WebGL preview of printing filament PLA material exported from 3ds Max to glTF/GLB  WebGL preview of printing filament SBS material exported from 3ds Max to glTF/GLB WebGL preview of printing filament TPU material exported from 3ds Max to glTF/GLB
Большинство шейдеров библиотеки имеет набор входов, настраивая которые вы можете создать уникальный материал, подходящий для ваших нужд. Кроме того, шейдеры имеют специальные входы для простого подключения запеченных нормалей и карт затенения.
Типичный рабочий процесс представлен на видео:
Пакет также содержит три специально разработанных HDR-карты окружения в 3-х разрешениях (1К, 2К и 4К)
Начало работы
Промышленная библиотека совместима с Autodesk Maya версии 2024 и выше.
После оформления заказа пакет материалов станет доступен для скачивания по ссылке, отправленной по электронной почте, а также в разделе загрузок на панели управления вашей учетной записи. Пожалуйста, ознакомьтесь с подробными инструкциями по эффективному использованию этих материалов в руководстве пользователя.
Отзывы
Отзывов пока нет.
Будьте первым, кто оставил отзыв на «Библиотека материалов Verge3D для Maya Промышленная»
Ваш адрес email не будет опубликован. Обязательные поля помечены *
Вам также будет интересно…
