NPOT Textures
  • 1000x500
  • 1200x800
  • 1920x1080
  • 500x1
  • 512x512
  • 2048x1024
  • 4096x4096
  • 128x1
WebGL 1.0
  • More memory consumption.
  • Reduced texture quality.
WebGL 2.0
  • NPOT textures cannot be compressed
Avoid using NPOT textures in Verge3D applications!
