3D Technologies and Solutions
Revision as of 12:40, 24 April 2025 by Alexander (talk | contribs)
ART
ATF
Bifrost
Node-based editor for visual effects. Distributed as a plug-in for Autodesk Maya.
BRDF
BSDF
BTDF
Hydra (HD)
Irradiance
LookdevKit
LookdevX
LTC
MaterialX
Mental Ray
MetaSL
Nitrous
3ds Max viewport system.
OGS
OpenPBR Surface
PMREM
Radiance
RapidRT
Stingray
