Tips for Verge3D devs
Revision as of 07:31, 8 May 2025 by Alexander (talk | contribs)
or to enable FPS counter:
// DONT FORGET TO REMOVE IT!
material.map = texture;
planeMesh.position.x = 6;
Code Indentation Style
The K&R style, 4 spaces:
function someFun() {
    const someConst = 10;
    const alwaysTrue = true;
        if (alwaysTrue) {
            console.log(`Hello ${i}!`);
Key Triplets
App Manager undocumented features
Restoring console functions
const i = document.createElement('iframe');
i.style.display = 'none';
document.body.appendChild(i);
window.console = i.contentWindow.console;
Downloading Electron builds
gh release download v19.0.4 -D v19.0.4 -p 'electron-*64.zip' -p 'electron-*32.zip' -p 'SHASUMS256.txt' -R electron/electron
Install Python packages to local directory
pip install --target=dir_name package_name
Installing Verge3D for Windows silently
verge3d-blender-4.9.2.exe /S
