3D Technologies and Solutions
Revision as of 09:00, 17 October 2024 by Alexander (talk | contribs)
ART
ATF
BRDF
BSDF
BTDF
Hydra (HD)
Irradiance
LookdevKit
LookdevX
Node-based material editor for USD assets which comes with Maya.
LTC
Mental Ray
MetaSL
Nitrous
3ds Max viewport system.
OGS
Radiance
RapidRT
Stingray
