Tips for Verge3D devs
or to enable FPS counter:
// DONT FORGET TO REMOVE IT!
material.map = texture;
planeMesh.position.x = 6;
Code Indentation Style
The K&R style, 4 spaces:
function someFun() {
const someConst = 10;
const alwaysTrue = true;
if (alwaysTrue) {
console.log(`Hello ${i}!`);
Key Triplets
- PPP — print performance profile. See here for more info.
- FFF — show/hide FPS counter in the upper left corner of the rendered canvas.
- HHH — halt/continue application rendering.
3ds Max SDK requirements
See here.
