3D Technologies and Solutions
Revision as of 18:24, 13 April 2026 by Alexander (talk | contribs) (Nitrous)
ART
ATF
Bifrost
Node-based editor for visual effects. Distributed as a plug-in for Autodesk Maya.
BRDF
BSDF
BTDF
Hydra (HD)
Irradiance
LookdevKit
LookdevX
LTC
MaterialX
Mental Ray
MetaSL
Nitrous
3ds Max viewport system. Based on OGS.
OGS
One graphics system, viewport renderer used in Autodesk software (3ds Max, Maya, AutoCAD, Inventor, Revit, Fusion, Infraworks, Navisworks, Recap, etc).
OpenPBR Surface
OSL
Open Shading Language. Used for physically accurate rendering.
PMREM
Radiance
RapidRT
RTSL
Ray Tracing Shading Language. Used for interactive ray tracing.
Stingray
