Tips for Verge3D devs
or to enable FPS counter:
// DONT FORGET TO REMOVE IT!
material.map = texture;
planeMesh.position.x = 6;
Code Indentation Style
The K&R style, 4 spaces:
function someFun() {
const someConst = 10;
const alwaysTrue = true;
if (alwaysTrue) {
console.log(`Hello ${i}!`);
Key Triplets
- PPP — print performance profile. See here for more info.
- FFF — show/hide FPS counter in the upper left corner of the rendered canvas.
- HHH — halt/continue application rendering.
Short Links
- v3d.net/api — open Verge3D API reference.
- v3d.net/ar — launch Augmented Reality demo.
- v3d.net/b — show system Benchmark result.
- v3d.net/c — launch basic Cube demo.
- v3d.net/g — launch Global Illumination demo.
- v3d.net/j — launch Jewelry Configurator.
- v3d.net/l — redirect to local App Manager (http://localhost:8668/).
- v3d.net/m — open Verge3D User Manual.
- v3d.net/r — launch Industrial Robot Demo.
- v3d.net/s — Scooter Demo.
- v3d.net/t — Teapot Heater.
- v3d.net/v — W3C Markup Validation Service.
- v3d.net/vr — launch Virtual Reality demo.
- v3d.net/w — WebGL System Report.
App Manager undocumented features
- localhost:8668/get_preview_dir — get path to preview directory.
- localhost:8668/update_all_apps — update all applications automatically (use with caution!).
- localhost:8668/restart — restart server.
- localhost:8668/stop — stop server.
- localhost:8668/reset — reset server settings.
- localhost:8668/log — App Manager log.
Restoring console functions
const i = document.createElement('iframe');
i.style.display = 'none';
document.body.appendChild(i);
window.console = i.contentWindow.console;
Downloading Electron builds
gh release download v19.0.4 -D v19.0.4 -p 'electron-*64.zip' -p 'electron-*32.zip' -p 'SHASUMS256.txt' -R electron/electron
Install Python packages to local directory
pip install --target=dir_name package_name
Installing Verge3D for Windows silently
verge3d-blender-4.9.2.exe /S
