Blender 4.2 migration guide
Revision as of 08:43, 19 February 2025 by Alexander (talk | contribs)
Transparency
Redundant Nodes
Shadows
Ambient Occlusion
Light Probes
Installing third-party extensions
For the reason unknown this might be set to "Soft8Soft" by default, which is definitely not right! Switch this prop to "User Default".
