Revision as of 13:21, 8 June 2026 by Sergey (talk | contribs)
Rhinoceros (Rhino 3D) is a popular CAD software used for product/industrial design (automotive, jewelry etc.) and architecture. This article shows you how to use this program to create interactive 3D web visualizations that work in the browser.
Verge3D offers an outstanding level of integration with Blender, 3ds Max, and Maya. It allows you to setup all the materials/lighting/cameras/animations using either of those tools and quickly preview in the web environment. This method is more robust even it requires transferring your 3dm asset into one of the said modelling software.
To transfer your models from Rhino to Blender you can use the OBJ format, while for 3ds Max / Maya the FBX format would be a more straightforward approach.
Manual Meshing
Rhino uses NURBS modeling, while for the WebGL rendering you will need polygons. For practical workflows this means you should perform the tessellation (meshing) manually in Rhino before exporting to glTF or transferring the models to Blender/3ds Max/Maya.
Got questions?
