Revision as of 13:17, 8 June 2026 by Sergey (talk | contribs)
Installing multiple versions of Verge3D side by side
verge3d-blender-4.12.0.exe /S
Using Linux version on Windows/macOS as portable
./setupAddon.py
setupAddon.bat install 5.1
./setupAddon.py install 5.1
regPlugPath.bat install 2027
./install.py
install.bat install 2027
./install.py install 2027
See here for instructions.
Verge3D for 3ds Max:
Verge3D for Maya:
Internet resources used
Host TCP Port Notes
Running Verge3D offline
Distributions of Verge3D
Accessing docs offline
